Where are solidworks serial numbers in registry?
Hi, I need to read the serial numbers from registry.
I found this path on a blog post, Just wanted to see if it is reliable for all versions of the app.
hklm:\Software\SolidWorks\Licenses\
Look here HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Licenses\Serial Numbers
You can have only 1 license number at a time in one machine. So even if you have multi versions installed, they will all use this number.
