In my project I’m projecting model points onto a View . Using View.ModelToViewTransform typically is all that is required. However, as I’m debugging some features that rely on the positions of Vertex s, I’m discovering something strange with Vertex.GetPoint() . It seems to return a spurious value, i.e., the position it returns matches none of the start or end coordinates of any Edge s connected to it. Is there some extra transform in play for a Vertex ? It would seem to me that GetPoint for a vertex and GetCurveParams3.StartPoint for an edge would both return “irreducible” coordinates.
With some testing I verified that Start/EndPoint do yield reliable model coordinates, but GetPoint does not. If you move the View around on the Sheet, it will yield different results. The docs don’t seem to hint at any transform intervening between model coordinates and GetPoint, but there must be one, or else it’s a flawed and useless value.
4I guess you got Vertex with GetVisibleEntities2 (swViewEntityType_e.swViewEntityType_Vertex), don’t use it, it’s wrong, I’ve had the same problem, Get the Edge with swViewEntityType_Edge, and then get the Vertex with GetStartVertex and GetEndVertex
@liuning the problem exists with the Vertex class (in a drawing, at least, which is where I'm concerned) regardless of whether the Vertex was gotten as Vertexs or as Edges then queried with Start/EndVertex...
@AmenJlili missing a transform is what I’ve suspected but I can’t find anywhere that indicates what that transform would be! Docs for GetPoint simply say “Array of three doubles representing the x, y, and z coordinates of the point”.
As for a repo, I suppose I might if I get time, but code is ultra minimal. Open a drawing in SWX. In a barebones standalone, simply get visible entities and select the first vertex. If you print GetPoint, you’ll see that its coordinates don’t match model coordinates. (One way to double check this is to print the coordinates of the start/end points of this Vertex’s Edges. None of them will match the coordinates of the Vertex itself. You can also see that GetPoint results will change if you drag the View around a bit and run the standalone again.
I have a solution that works, at least in the scenarios that I’m concerned with.
GetPoint is still useless without knowing whether there’s an undocumented transform, or just an error, and that still bugs me.
But you can get the true model coordinates of the Vertex by cycling through its GetEdges, and examining their CurveParams->Start/EndPoints, and finding a coordinate set that is common. These are true model coordinates, and can be safely used with View.ModelToViewTransform to project model coordinates into Sheet space.
transform1 = view => ModelToViewTransform;
transform2 = view => GetSketch => ModelToSketchTransform;
Pt = pt => transform1 => transform2
@liuning I'm not getting correct coordinates even with involving ModelToSketchTransform. I tried using MTS alone, I tried multiplying by MTV then by MTS, and I tried multiplying by MTS and then by MTV. No results so far are correct. All of these values start with GetPoint on the Vertex.
– JohnwzI also tried throwing some .Inverse() of the same transforms into the equation, but still, no transformation combination that I've tried has worked.
– JohnwzIf you inverse the ModelToSketchTransform, then take the translation components (TX, TY, TZ). Subtract the translation components from the point (PX, PY, PZ), this will give you accurate coordinates in true 3d model space. Janky but seems to work so far...
– tbrenn94
I have a feeling you are a missing a transform somewhere in the chain of the transforms. Ideally, I'd create a public repo with a sample file and some code to show the issue. Others will be able to see what you're seeing. Eventually, if no one can find a solution, the repo can be sent to API support.
– AmenJlili
