I have a reference to an IComponent2 within the context of the active document. I also have the name of a dimension that I’m trying to get the value from “D1@Dimensions”. Does anyone have a macro that can do this ?
Public Function GetDimensionValue(ByVal swComponent as Component2, ByVal dimension as String) as Double
' code goes here
Thanks!
Close enough :
Public Function GetDimensionValue(ByVal mainAssemblyModelDoc As ModelDoc2, ByVal swComponent As Component2, ByVal dimensionName As String) As Double
Dim swSelMgr As SldWorks.SelectionMgr
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.dimension
Dim dimValue As Variant
Dim status As Boolean
Set swSelMgr = mainAssemblyModelDoc.SelectionManager
status = mainAssemblyModelDoc.Extension.SelectByID2(dimensionName + "@" + swComponent.GetSelectByIDString, "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set swDispDim = swSelMgr.GetSelectedObject6(1, -1)
Set swDim = swDispDim.GetDimension
dimValue = swDim.GetSystemValue2(swComponent.ReferencedConfiguration)
GetDimensionValue = dimValue
Yes, building the complete string to the dimension seems to be the only way. I get dimension values the exact same way.
