I’m looking for a helper method in VBA or C# that sets an appearance to a component. I’m interested in applying a color to a selected component.
Any suggestions would be helpful!
For VBA look at this example
For C# you can see how it is implemented in the xCAD.NET:
And here is integration/unit test for usage:
Thanks @artem! So this can be summarized to this:
public static void SetColor(this Component2 component, Color color)
SetColor(color, null,
(m, o, c) => component.SetMaterialPropertyValues2(m, (int)o, c),
(o, c) => component.RemoveMaterialProperty2((int)o, c));
internal static void GetColorScope(IComponent2 comp, out swInConfigurationOpts_e confOpts, out string[] confs)
confOpts = comp != null
? swInConfigurationOpts_e.swSpecifyConfiguration
: swInConfigurationOpts_e.swThisConfiguration;
confs = comp != null
? new string[] { comp.ReferencedConfiguration }
: null;
internal static double[] ToMaterialProperties(Color color)
=> new double[]
color.R / 255d,
color.G / 255d,
color.B / 255d,
1, 1, 0.5, 0.4,
(255 - color.A) / 255d,
0
internal static void SetColor(Color? color,
IComponent2 ownerComp,
Action<double[], swInConfigurationOpts_e, string[]> setColorAction,
Action<swInConfigurationOpts_e, string[]> removeColorAction)
GetColorScope(ownerComp, out swInConfigurationOpts_e confOpts, out string[] confs);
if (color.HasValue)
var matPrps = ToMaterialProperties(color.Value);
setColorAction.Invoke(matPrps, confOpts, confs);
else
removeColorAction?.Invoke(confOpts, confs);
Hi!
I’m sorry to re-open this question but I don’t feel link to open a new one.
Searching online I saw to ways to change the color of a component:
GetDisplayStateSetting and DisplayStateSpecMaterialPropertyValues as shown here
I wonder what are the main differences between the two and if there are any pro or cons using one method or the other.
Furthermore if I use the second method, even with the example from the SolidWorks API Help, the changed component appears black unless the component is closed and re-opened or the appearance is changed from the UI. I saw others complaining about this behavior:
Any idea or suggestion?
Thanks in advance.
I would highly highly appreciate it if you could open a new question.
This will give your question more visibility on the site and the internet.
Opening a new question takes as long as writing a new reply.
Thank you.
