Unlock File Issue
Hi, everybody!
I have an issue to unlock new added file
var vault1 = new EdmVault5();
vault1.LoginAuto(“PDM”, 0);
string ProductFile = ProductFolderName + “.SLDASM”;
IEdmFolder6 folderObj = (IEdmFolder6)vault1.GetFolderFromPath(ModelFolder.LocalPath);
folderObj.AddFile(0, TemplatePath, ProductFile, (int)EdmAddFlag.EdmAdd_Simple);
folderObj.Refresh();
IEdmFile5 ModelFile = folderObj.GetFile(ProductFile);
if (ModelFile != null)
if (ModelFile.IsLocked)
ModelFile.UnlockFile(0, “Auto imported.”);
The new file adding successfully, but when i’m trying to unlock file PDM return error HRESULT = 0x80040229 The file format is not recognized
The file is normal, i can it open in Solidworks and Unlock manual
I was able to reproduce this issue. To solve this, you will need to edit your project properties in visual studio and make sure that “Prefer 32-bit” is un-checked on the “Build” tab.
While you’re at it, make sure that the “Embed Interop Types” for your PDM .dll files are set to False
A tip with the code, AddFile provides the new file ID when it finishes. You can then use this to obtain a reference to the file rather than having to keep track of the name.
var vault = new EdmVault5() as IEdmVault21;
if(!vault.IsLoggedIn)
    vault.LoginAuto(vaultName, 0);
var pdmFolder = vault.GetFolderFromPath(destinationFolderPath);
var newFileId = pdmFolder.AddFile(0, sourceFilePath, "AddedFileName.sldprt", (int)EdmAddFlag.EdmAdd_Simple);
var addedModel = vault.GetObject(EdmObjectType.EdmObject_File, newFileId) as IEdmFile17;
if(addedModel != null)
    if(addedModel.IsLocked)
        addedModel.UnlockFile(0, "Automatically Checked In", (int)EdmUnlockFlag.EdmUnlock_Simple);
Thank you very much! I have uncheck “Prefer 32-bit” and the file was unlocked
Hello!
check if ModelFile is nothing before ModelFile.UnlockFile()
adding of new files can take some time…
if file is nothing, insert Threading.Thread.Sleep(25000) before “.getfile”
the file is very small size and It doesn't take much time. But Thank you very much!
