Standalone SOLIDWORKS taskpane (HTML/JS + VBA) - hide Origins/Planes/Axes/Sketches/Curves, works in Part + Assembly, EN/IT toggle
Goal
Sharing a small self-contained VBA class that adds a custom taskpane panel to SOLIDWORKS with checkboxes to bulk-hide reference geometry (origins, planes, axes, points, coordinate systems, 2D/3D sketches, curves, composite curves, helix/spiral). Works on both parts and assemblies (recursively through components), and includes a client-side EN/IT language toggle in the panel itself. No dependency on SOLIDWORKS CAM or any add-in framework - it only needs the SOLIDWORKS core Type Library and Microsoft Internet Controls, so it should drop into any SOLIDWORKS 2024 install as a standalone macro. Posting it here mainly to get some outside testing and feedback - curious if it behaves the same on other setups, especially with deeply nested assemblies or large component trees.
Environment
GestisciVisibiltĂ .swp (120,5 KB)
  • SOLIDWORKS version: SOLIDWORKS 2024
  • API surface: Desktop API (SldWorks core only, no CAMWorksLib dependency)
  • Language and runtime: VBA
  • Add-in, macro, or standalone app: Standalone macro (creates and destroys its own SldWorks.TaskpaneView, no add-in registration needed)
Actual Behavior
Tested on SOLIDWORKS 2024 with both a single part and a multi-level assembly: the panel opens as an embedded WebBrowser taskpane, all checkboxes toggle correctly, “All”/“None” work, the mask is passed back to VBA via a custom cadcam:// URL scheme intercepted in BeforeNavigate2, and BlankRefGeom/BlankSketch hide the selected feature types across the whole component tree. The EN/IT toggle switches all labels instantly, purely client-side. Would appreciate feedback on: - behavior on SOLIDWORKS versions other than 2024 - performance on assemblies with a very large number of components - whether swVisibilityStateShown/swVisibilityStateUnknown cover all the visibility states you’d expect in your own models
3
Thank you for sharing :slight_smile:
Nice one. I thought you couldn’t create task panes from VBA, so I learned something.
Also, using a web view for the task pane could let me update an add-in without having to send out an update. That only works for UI changes, but still.
Exactly, this solution lets you do some incredible things. I've actually been using it to quickly manage 2.5-axis CAM commands and handle toolpath post-processing.
Thank a lot for this sharing.
