Hello, I’m trying to get the SolidWorks bom of an assembly out of the PDM.
I can do it using a sotred procedure as an example.
But it does not consider when ShowChildComponentsInBOM_Promote=2, the children are not “promoted” to the parent. Someone knows how to do it? Thanks in advance. regards
That is a SOLIDWORKS setting? What BOM layout are you using?
Hi, you can set it in the CAD. Than you can get it in the result of the SP that the PDM is using for bom. But I need to get the BOM “promoted” that’s not available from API (at least from my knowledge) . I did it with a dedicated SP, but I would like to understand if there is more “robust” and “official”. But from the respoinse, I guess no. Thanks
