SOLIDWORKS PDM API UnlockFile(s)
When developing an application with newer versions of .NET, it’s always a bit risky as the recommendation from SOLIDWORKS is to use the highest version of .NET Framework. I’m working on a more modern application, which I currently have targeting .NET 10, which has been great for everything so far, except when I was testing my check-in logic from either, IEdmFile5.UnlockFile or IEdmBatchUnlock2.UnlockFiles would result in a hard crash, non catchable exception.
Faulting module name: ntdll.dll, version: 10.0.26100.8246, time stamp: 0xf7576e9e
Exception code: 0xc0000409
Fault offset: 0x0000000000120fc6
My process to figure this out was to ask the almighty chat bots with no success. I figured that there was something out there that was an edge case from something totally unrelated that would solve all the world’s problems, but yet they still remain. Next I tested the same code in a .NET 10 console app, same crash. On to something that works- .NET Framework 4.8- which validated the code was correct and there was something else at play here. After a few minutes of going back and forth with a .NET console app, I found that the highest version that doesn’t crash is .NET 8.
I will update if I find anything else that prevents me from using .NET 8, but for now, let’s just say that it works as intended and is compatible with the rest of my project.
Note, this is paired with SOLIDWORKS PDM 2024 SP5.
I think I have seen this exception too.
Have you checked you Visual Studio target platform? You should either uncheck 'Prefer 32-bit' or just choose x64.
