Hello, is it possible to remove a reference using SolidWorks Document Manager Library? Thanks for info. best regards Massimo
It’s possible to replace file references by providing the old path and new path to the file, however I don’t think it can remove references outright.
I think you may be looking at your issue from the wrong angel. What are you trying to achieve?
You can remove a reference by breaking it (replacing it using the API), or,
You can remove the SOLIDWORKS feature that depends on that external reference (component…)
