I’m trying to show the flat pattern’s fixed face for any selected sheetmetal part in the assembly.
I already tried the method swEntity.Select3 the return value is True but nothing is selected.
You need to post some code with an example assembly.
Got it!
Dim swComp As SldWorks.Component2
Dim swEnt As SldWorks.Entity
Sub Main()
Dim Sheetmetal_Flatpattern_Name As String
If swModel.GetType = swDocPART Then
Sheetmetal_Flatpattern_Name = Get_Flatpattern_Name(swModel)
Set swComp = swModel.SelectionManager.GetSelectedObjectsComponent2(1)
Sheetmetal_Flatpattern_Name = Get_Flatpattern_Name(swComp.GetModelDoc2)
Set swEnt = swComp.GetCorrespondingEntity(swEnt)
swEnt.Select False
Private Function Get_Flatpattern_Name(ByVal Ref_Model As SldWorks.ModelDoc2) As String
Dim Ref_Feat As SldWorks.Feature
Dim Ref_SheetMetal As SldWorks.SheetMetalFeatureData
Dim Ref_FlatPattern As SldWorks.FlatPatternFeatureData
Dim Ref_Face As SldWorks.Face2
Set Ref_Feat = Ref_Model.FirstFeature
Do While Not Ref_Feat Is Nothing
If Ref_Feat.GetTypeName2 = "FlatPattern" Then
Get_Flatpattern_Name = Ref_Feat.name
Exit Do
Set Ref_Feat = Ref_Feat.GetNextFeature
Loop
Set Ref_FlatPattern = Ref_Feat.GetDefinition
Ref_FlatPattern.AccessSelections Ref_Model, Nothing
Set Ref_Face = Ref_FlatPattern.FixedFace2
Ref_FlatPattern.ReleaseSelectionAccess
Set swEnt = Ref_Face
Set swEnt = swEnt.GetSafeEntity
This was the missing line in the code:
It seems like you’re attempting to write a macro in SolidWorks to select the fixed face of a sheet metal part. Here’s a basic example of how you could achieve this:
Dim swPart As SldWorks.PartDoc
Dim swFlatPatternFeature As SldWorks.FlatPatternFeature
Dim swSelMgr As SldWorks.SelectionMgr
Sub Main()
If Not swModel Is Nothing Then
Set swPart = swModel
If swPart.IsSheetMetal Then
Set swFlatPatternFeature = swPart.FeatureByName("Flat-Pattern1") ' Change "Flat-Pattern1" to match your flat pattern feature name
If Not swFlatPatternFeature Is Nothing Then
swFlatPatternFeature.Select2 True, 0 ' Select the flat pattern feature
Set swSelMgr = swModel.SelectionManager
Dim selectedFace As SldWorks.Face2
Set selectedFace = swSelMgr.GetSelectedObject6(1, -1) ' Get the selected face
If Not selectedFace Is Nothing Then
MsgBox "Selected face: " & selectedFace.Name
MsgBox "No face selected"
MsgBox "Flat pattern feature not found"
MsgBox "Selected part is not a sheet metal part"
MsgBox "Selected document is not a part"
MsgBox "No active document"
