Saveas file with a windows to select location
In SolidWorks, is it possible to ‘Save As’ using a window that opens?
At the moment, I’m using a workaround via Excel.
The aim is to save a file to a location of the user’s choice, and then to be able to select the file in a second window.
Exemple with Excel:
Dim swModel As ModelDoc2
Dim swExt As ModelDocExtension
Dim bRet As Boolean
Sub addSameLink()
    ' === Vérifie document ===
    If swModel Is Nothing Then
        MsgBox "Aucun document actif", vbExclamation
        Exit Sub
    Set swExt = swModel.Extension
    ' === Chemin fichier ===
    Dim swPath As String
    swPath = swModel.GetPathName
    ' === Enregistrer si nécessaire ===
' === Enregistrement si nécessaire ===
If swPath = "" Then
    Dim xlApp2 As Object
    Dim fd2 As Object
    Dim folderPath As String
    Dim fileName As String
    Dim fullPath As String
    Dim errors As Long
    Dim warnings As Long
    ' Lancement Excel
        Set xlApp2 = CreateObject("Excel.Application")
        Set fd2 = xlApp2.FileDialog(4) ' 4 = FolderPicker
        With fd2
            .Title = "Choisir le dossier d'enregistrement de la pièce"
            .AllowMultiSelect = False
            If .Show <> -1 Then
                MsgBox "Aucun dossier sélectionné.", vbExclamation
                xlApp2.Quit
                Set xlApp2 = Nothing
                Exit Sub
            folderPath = .SelectedItems(1)
        End With
        ' Fermeture Excel
        xlApp2.Quit
        ' Nom basé sur la pièce
        fileName = swModel.GetTitle
        If InStrRev(fileName, ".") > 0 Then
            fileName = Left(fileName, InStrRev(fileName, ".") - 1)
        ' Chemin final
        fullPath = folderPath & "\" & fileName & ".sldprt"
        ' Sauvegarde
        Debug.Print fullPath
        Dim saveOk As Boolean
        saveOk = swModel.Extension.SaveAs3(fullPath, 0, 0, Nothing, Nothing, errors, warnings)
        If saveOk = False Then
            MsgBox "Erreur lors de l'enregistrement.", vbCritical
            Exit Sub
    ' === Chemin PDF attendu ===
    Dim pdfPath As String
    pdfPath = Left(swPath, InStrRev(swPath, ".") - 1) & ".pdf"
    Debug.Print "PDF attendu : " & pdfPath
    ' === Si PDF absent => sélection utilisateur ===
    If Dir(pdfPath) = "" Then
        Dim xlApp As Object
        Dim fd As Object
        Dim selectedFile As String
        ' ? Lancement Excel (solution fiable)
        Set xlApp = CreateObject("Excel.Application")
        Set fd = xlApp.FileDialog(3) ' FilePicker
        With fd
            .Title = "Sélectionner la fiche technique du MR (Fichier Pdf qui sera renommé et déplacé automatiquement)"
            .filters.Clear
            .filters.Add "Fichiers PDF", "*.pdf"
            ' Option : ouverture dans le bon dossier
            .InitialFileName = Left(swPath, InStrRev(swPath, "\"))
            If .Show <> -1 Then
                MsgBox "Aucun fichier sélectionné.", vbExclamation
                xlApp.Quit
                Set xlApp = Nothing
                Exit Sub
            selectedFile = .SelectedItems(1)
        End With
        ' Fermeture Excel
        xlApp.Quit
        Set xlApp = Nothing
        ' === Vérifications ===
        If LCase(Right(selectedFile, 4)) <> ".pdf" Then
            MsgBox "Le fichier sélectionné n'est pas un PDF.", vbCritical
            Exit Sub
        ' === Copie + renommage ===
        Dim fso As Object
        Set fso = CreateObject("Scripting.FileSystemObject")
        On Error Resume Next
        fso.MoveFile selectedFile, pdfPath
        If Err.Number <> 0 Then
            MsgBox "Erreur lors de la copie du PDF.", vbCritical
            Exit Sub
        On Error GoTo 0
    ' === Ajout Design Binder ===
    Dim bRes As Boolean
    bRes = swExt.InsertAttachment(pdfPath, True)
    If bRes Then
        Dim swCustProp As CustomPropertyManager
        Set swCustProp = swExt.CustomPropertyManager("")
        bRet = swCustProp.Add3("Material", _
                              swCustomInfoType_e.swCustomInfoText, _
                              "Pdf", _
                              swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
                              MsgBox "Fiche technique motoréducteur(pdf) ajouté au classeur de conception."
        MsgBox "Echec de l'insertion du PDF", vbExclamation
    ' === Sauvegarde finale ===
    Dim errorsSave As Long
    Dim warningsSave As Long
    Dim saveFinalOk As Boolean
    saveFinalOk = swModel.Save3(0, errorsSave, warningsSave)
    If saveFinalOk = False Or errorsSave <> 0 Then
        MsgBox "Erreur lors de la sauvegarde finale. Code : " & errorsSave, vbCritical
        Debug.Print "Fichier sauvegardé avec succès."
I’ do not think there is any method other than MS office or WinApi to get that window. I would be interested to know however.
This should work:
swApp.RunCommand swCommands_e.swCommands_SaveAs, “Save As”
But I don’t know how to get the name of the saved file. Maybe you can try to use a post save event handler.
