Save assembly as eDrawing with all configurations
I’m trying to write a VBA macro to save the active assembly as an eDrawing with all its configurations.
The SolidWorks UI allows to select which configuration to include in the eDrawing when using File → Publish to eDrawings. I taught that the API would allow the same behavior, according to this, but when I tried with the sample code below only the active configurations is exported.
I don’t know if the problem is related to the fact that I’m using the Extension.SaveAs3 method to save… is there another one to mimic the publish command?
' Export the active model as eDrawing
Const OUT_FOLDER As String = "C:\_Export"
Const OUT_NAME As String = "C:\_Export\test.easm"
    Dim swModel As ModelDoc2
    ' Exit if model is not an assembly
    If Not swModel.GetType() = swDocumentTypes_e.swDocASSEMBLY Then
        GoTo finally_
    ' Get model configurations
    Dim vConfs As Variant
    If swModel.GetType() = swDocumentTypes_e.swDocDRAWING Then
        vConfs = swModel.GetSheetNames()
        vConfs = swModel.GetConfigurationNames()
    ' Create output directory
    CreateDirectories OUT_FOLDER
    ' * Export file
    Dim exportResult As Boolean
    Dim errs As Long
    Dim warns As Long
    Dim AdvOptData As AdvancedSaveAsOptions
    Set AdvOptData =  swModel.Extension.GetAdvancedSaveAsOptions((1 + 2 + 4))
    ' Set the Publish to eDrawing options
    ' https://help.solidworks.com/2018/english/api/swconst/FilePublishToEDrawings.htm
    SetExportOption vConfs
    ' Set the advanced save as options
    ' https://help.solidworks.com/2022/english/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.IAdvancedSaveAsOptions~ConfigurationsToSave.html?verRedirect=1
    AdvOptData.ConfigurationsToSave = vConfs
    exportResult = swModel.Extension.SaveAs3(OUT_NAME, swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, Nothing, AdvOptData, errs, warns)
    finally_:
Sub SetExportOption(vConfig As Variant)
    Dim configNames As String
    configNames = ""
    For i = 0 To UBound(vConfig)
        configNames = configNames & CStr(vConfig(i))
        If i <> UBound(vConfig) Then
            configNames = configNames & vbNewLine
    Dim value as String
    swApp.SetUserPreferenceStringListValue swUserPreferenceStringListValue_e.swEmodelSelectionList, configNames
Sub CreateDirectories(path As String)
    Dim FSO As Object
    Set FSO = CreateObject("Scripting.FileSystemObject")
    If FSO.FolderExists(path) Then
        Exit Sub
    CreateDirectories FSO.GetParentFolderName(path)
    FSO.CreateFolder path
Add below line before doing the saveas
swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll
Here is one quick example that would works for parts, assemblies and drawings.
Dim nErrors As Long
Dim nWarnings As Long
    swModel.Extension.SaveAs OutPutFileNameHere, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
Thanks a lot, I totally missed that one!
