Running a Macro on multiple drawings
Hello,
I have a working macro that I’ve managed to cobble together. It deletes a block from the title block of a drawing, then inserts a specific block, in a certain place, based on the sheet size.
However, I’m trying to tweak this so it can run on all drawings within a folder.
I have a version (massive thanks to Deepak Gupta for his help) which I believe is 90% correct but it’s still throwing up an error - ‘Variable not defined’ and I can’t figure out why.
I’ll post the original macro that works on single drawings manually, and then I’ll also post my version which tries to make this work for all drawings in a folder but isn’t working.
Please could anyone help me get this working, as I have a whole load of drawings to apply this to!
Thanks a lot!
Johno
Here’s the original working code:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2(“Sheet1”, “SHEET”, 0.37573258774438, 0.213815049989652, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2(“TITLE BLOCK LOGO-1”, “SKETCHPOINT”, 0.376092469963706, 0.101224236733452, 0, False, 0, Nothing, 0)
Part.EditDelete
boolstatus = Part.Extension.SelectByID2(“TITLE BLOCK LOGO-2”, “SKETCHPOINT”, 0.284947555369359, 0.173177575046838, 0, False, 0, Nothing, 0)
Part.EditDelete
boolstatus = Part.Extension.SelectByID2(“TITLE BLOCK LOGO-3”, “SKETCHPOINT”, 0.29645168323629, 0.205863420406613, 0, False, 0, Nothing, 0)
Part.EditDelete
boolstatus = Part.Extension.SelectByID2(“TITLE BLOCK LOGO-4”, “SKETCHPOINT”, 0.29645168323629, 0.205863420406613, 0, False, 0, Nothing, 0)
Part.EditDelete
Part.EditDelete
boolstatus = Part.Extension.SelectByID2(“TITLE BLOCK LOGO-5”, “SKETCHPOINT”, 0.29645168323629, 0.205863420406613, 0, False, 0, Nothing, 0)
Part.EditDelete
boolstatus = Part.Extension.SelectByID2(“TITLE BLOCK LOGO-6”, “SKETCHPOINT”, 0.29645168323629, 0.205863420406613, 0, False, 0, Nothing, 0)
Part.EditDelete
Part.EditDelete
Part.EditSheet
Set swDraw = swApp.ActiveDoc
Set swSheet = swDraw.GetCurrentSheet
' Get current sheet properties
vSheetProps = swSheet.GetProperties
' Current sheet properties
Debug.Print "  PaperSize                 = " & vSheetProps(0)
'0 = A Landscape (11x8.5"), 2 = B (17x11"), 4 = E (Not Set)
Part.EditTemplate
Part.EditSketch
Part.EditSheet
Part.EditSketch
Dim swSktManager As SldWorks.SketchManager
Dim swMathUtility As SldWorks.MathUtility
Dim swMathPoint As SldWorks.MathPoint
Dim PointCoords(2) As Double
Dim swSktBlkDef As SldWorks.SketchBlockDefinition
Dim scl As Double
Dim angle As Double
' Change scale and angle here
scl = 1
angle = 0
Part.EditTemplate
Part.EditSketch
Set swSktManager = swModel.SketchManager
Set swMathUtility = swApp.GetMathUtility
Select Case vSheetProps(0)
Case “0”
’ A Size (Change Position of Logo Here)
PointCoords(0) = 0.1875 ’ X
PointCoords(1) = 0.015 ’ Y
PointCoords(2) = 0 ’ Z
Case “1”
'Not Specified
PointCoords(0) = 0.25 ’ X
PointCoords(1) = -0.05 ’ Y
Case “2”
’ B size (Change Position of Logo Here)
PointCoords(0) = 0.34    ' X
PointCoords(1) = 0.01425 ' Y
PointCoords(2) = 0 ' Z
'Add extra sizes here if needed, using Case "3" etc.
End Select
Set swMathPoint = swMathUtility.CreatePoint(PointCoords)
'Set Block file location here ->
    Set swSktBlkDef = swSktManager.MakeSketchBlockFromFile(swMathPoint, "D:\Documents\LOGO.SLDBLK", False, scl, angle)
Part.EditSheet
Part.EditSketch
and here’s the version with the folder select, that doesn’t quite work:
'Batch Delete Block, then Insert Based on Paper Size.swp ------------- 06/16/21
'Description: Macro to Delete Block, then Insert Based on Paper Size.
’ Macro would process all drawing files in the specified folder and it’s sub folders.
'Folder Browse Codes: Browse For Folder
'Please back up your data before use and USE AT OWN RISK
’ This macro is provided as is. No claims, support, refund, safety net, or
’ warranties are expressed or implied. By using this macro and/or its code in
’ any way whatsoever, the user and any entities which the user represents,
’ agree to hold the authors free of any and all liability. Free distribution
’ and use of this code in other free works is welcome. If any portion of
’ this code is used in other works, credit to the authors must be placed in
’ that work within a user viewable location (e.g., macro header). All other
’ forms of distribution (i.e., not free, fee for delivery, etc.) are prohibited
’ without the expressed written consent by the authors. Use at your own risk!
’ Written by: Deepak Gupta (http://gupta9665.com/)
Dim swDraw As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim vSheetProps As Variant
Dim nErrors As Long
Dim nWarnings As Long
Dim sFileName As String
Dim Path As String
Dim vSheetName As Variant
Dim i As Long
Dim nTemplatePath As String
Dim swPaperWidth As String
Dim mFolder As Variant
Dim sFolder As Variant
Dim fso As Object
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Function BrowseFolder(Optional Caption As String, Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.Folder
Set SH = New Shell32.Shell
Set F = SH.BrowseForFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
If Not F Is Nothing Then
If F = “Desktop” Then
BrowseFolder = Environ(“USERPROFILE”) & “\Desktop”
BrowseFolder = F.Items.Item.Path
Path = BrowseFolder()
If Path = "" Then
MsgBox "Please select the path and try again"
End
Path = Path & "\"
ProcessDrawings Path
Sub ProcessDrawings(sPath As String)
sFileName = Dir(Path & “*.slddrw”)
Do Until sFileName = “”
Set swModel = swApp.OpenDoc6(Path + sFileName, swDocDRAWING, swOpenDocOptions_Silent, “”, nErrors, nWarnings)
vSheetName = swModel.GetSheetNames
For i = 0 To UBound(vSheetName)
swModel.ActivateSheet vSheetName(i)
Set swSheet = swModel.GetCurrentSheet
    'edit sheet format and delete blocks
        swModel.EditTemplate
        swModel.EditSketch
        boolstatus = swModel.Extension.SelectByID2("TITLE BLOCK LOGO-1", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
        swModel.EditDelete
        boolstatus = swModel.Extension.SelectByID2("TITLE BLOCK LOGO-2", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
        swModel.EditDelete
        boolstatus = swModel.Extension.SelectByID2("TITLE BLOCK LOGO-3", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
        swModel.EditDelete
        boolstatus = swModel.Extension.SelectByID2("TITLE BLOCK LOGO-4", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
        swModel.EditDelete
        swModel.EditDelete
        boolstatus = swModel.Extension.SelectByID2("TITLE BLOCK LOGO-5", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
        swModel.EditDelete
        boolstatus = swModel.Extension.SelectByID2("TITLE BLOCK LOGO-6", "SKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
        swModel.EditDelete
        swModel.EditDelete
        swModel.ClearSelection2 True
        swModel.EditSheet
        'Set Position of Logo based on sheet size
        Select Case vSheetProps(0) ' Get paper size
        Case "0"
        ' A Size (Change Position of Logo Here)
        PointCoords(0) = 0.1875 ' X
        PointCoords(1) = 0.015 ' Y
        Case "1"
        'Not Specified
        PointCoords(0) = 0.25 ' X
        PointCoords(1) = -0.05 ' Y
        Case "2"
        ' B size (Change Position of Logo Here)
        End Select
        swModel.ViewZoomtofit2
Next i
        swModel.ActivateSheet vSheetName(0)
        swModel.Save3 swSaveAsOptions_Silent, nErrors, nWarnings
        swApp.CloseDoc swModel.GetTitle
        Set swDraw = Nothing
sFileName = Dir
Loop
'Process files in sub folders
Set fso = CreateObject(“Scripting.FileSystemObject”)
Set mFolder = fso.GetFolder(sPath)
For Each sFolder In mFolder.subFolders
ProcessDrawings sFolder.Path & ""
Try Batch+
This is absolutely excellent! It’s exactly what I needed. Thanks so much.
(If anyone has any info about the other way too, I’d be happy to hear it, just for my own knowledge)
In case anyone is looking for this - the excellent Deepak Gupta got it working.
This macro opens all drawings in a folder, then deletes any blocks in the Sheet Format/Title Block, then it inserts a new block (specify the location of this within the code) in the corner, depending on the sheet size.
Here’s the code:
'Folder Browse Codes: [link removed]
Dim nErrors As Long
Dim Path As String
Dim i As Long
Dim fso As Object
Dim scl As Double
Dim Angle As Double
If Path = "" Then
End
Path = Path & "\"
        swModel.EditSketch
        swModel.EditDelete
        swModel.EditDelete
        swModel.EditDelete
        swModel.EditDelete
        swModel.EditDelete
        swModel.EditDelete
        swModel.EditDelete
        swModel.EditDelete
        Case "0"
        Case "1"
        'Not Specified
        Case "2"
        End Select
        scl = 1
        Angle = 0
        Set swSktBlkDef = swSktManager.MakeSketchBlockFromFile(swMathPoint, "D:\Documents\LOGO.SLDBLK", False, scl, Angle)
        swModel.EditSheet
Next i
sFileName = Dir
Loop
