Run attached VSTA macro
Is it possible to run VSTA macro, which is attached in the design binder, from a second VBA macro, using the RunAttachedMacro method?
Since the RunAttachedMacro takes the macro name, module name, and procedure name as parameters, I tried setting up my vsta macro like this:
Partial Class SolidWorksMacro
Public Sub main()
    MsgBox("To dela")
''' <summary>
''' The SldWorks swApp variable is pre-assigned for you.
''' </summary>
Public swApp As SldWorks
End Class
Module HandlerModule
Dim macro As New SolidWorksMacro
Public Sub main()
    macro.main()
End Module
Unfortunatly unsuccessful.
Posnetek zaslona 2024-05-31 212911
3
What’s the purpose of attaching the macro file into the model? How could you run it on SW?
If you attach the macro, anyone who opens this part can run the attached macro. Otherwise, you have to provide the macro in a separate file.
Maybe it’s possible if you attach an executable macro file.
You can. I would not do that. It looks like a virus.
Here’s how you do it through:
  • Write an add-in that downloads the file from the binder.
  • Load the DLL in memory.
  • Invoke the entry point by supplying the swApp instance from your add-in.
