PDM - How to increment a variable on workflow transition
Hello, how is possible to change a variable (is not a revision) value, for example increment or change it by an “expression” in a workflow transition?
In the available actions, I can set a variable, but seems you cannot insert expression.
Es. Variable = Variable + 10?
I tried via a trigger in TransationHistory SQL with stored procedure SPU_UpdVar,
but it change value only on the DB, not in the datacard.
Thanks for any info. Best regards
Massimo
Hi, it’s possible to create a Dispatch Action, that increment the value. Thanks, regards Massimo
@ammcomputer: Thanks for posting! It would be great to share your findings as well. The more information we share with our friends, the better the forum gets.
