Hello,
I just wrote a Makro that writes some custom properties of a 3D-Model in a particular way before we export them to our ERP-System. At the End i would like the Makro to open the Datacard with all the relevant infos . Because it´s what every user will do after the makro to check if it worked like supposed to. So why not implement it. I didn’t think it would be so complicated …
Is there an easy way of doing that ? I think the funktion IEdmCardview.ShowWindow ist the one i need, but don´t know how to acces IEdmCardView. Can anyone help me ?
I’m running the Makro directly von Solidworks (2022), I wrote the code in VBA, and we are using SOLIDWORKS PDM 2022-
Here is the Code i have so far:
Sub OpenPDMDocumentCard()
' Declare variables
Dim pdmVault As IEdmVault5
Dim pdmFile As IEdmFile5
Dim pdmFolder As IEdmFolder13
Dim pdmCard As IEdmCard7
Dim pdmCardView As IEdmCardView64
Dim selectionList As Object
Dim pathFi As String
Dim pathFo As String
Dim myExt As String
Dim pdmCardID As String
' Get the SOLIDWORKS application
' Check if a document is open
If swApp.ActiveDoc Is Nothing Then
MsgBox "No document is currently open."
Exit Sub
' Get the active model
pathFi = swModel.GetPathName
Debug.Print pathFi
pathFo = Left(pathFi, InStrRev(pathFi, "\"))
Debug.Print pathFo
myExt = Right(pathFi, Len(pathFi) - InStrRev(pathFi, "."))
Debug.Print myExt
' Get the PDM vault
Set pdmVault = CreateObject("ConisioLib.EdmVault")
' Check if the document is managed by PDM
If pdmVault Is Nothing Then
MsgBox "The document is not managed by SOLIDWORKS PDM."
Exit Sub
If Not pdmVault.IsLoggedIn Then pdmVault.Login "admin", "nimda", "Drehtainer"
' Get the PDM file
Set pdmFile = pdmVault.GetFileFromPath(pathFi)
' Check if the file is found in the vault
If pdmFile Is Nothing Then
MsgBox "The document is not found in the SOLIDWORKS PDM vault."
Exit Sub
'Get PDM Folder
Set pdmFolder = pdmVault.GetFolderFromPath(pathFo)
' Get CardID
pdmCardID = pdmFolder.GetCardID(myExt)
'Get Card
Set pdmCard = pdmFolder.GetCard(myExt)
' Get the card view for the document
Set pdmCardView = pdmCard.
pdmCardView.ShowWindow
' Check if the card view is available
If pdmCardView Is Nothing Then
MsgBox "The document does not have a PDM Data card."
Exit Sub
' Show the card view window
pdmCardView.ShowWindow True
I have been able to get it to show up, but it’s not usable in any way. I’ve looked into implementing the callback interface that’s recommended but that still doesn’t handle clicking, typing, etc. I suspect this may be a limitation of VBA but it’s hard to say without trying this with c# for vb.net.
Module Code:
Public Const VAULT_NAME As String = "your vault name here"
Dim swModel As ModelDoc2
Dim myForm As UserForm1
Set myForm = New UserForm1
Debug.Assert Not myForm Is Nothing
myForm.Setup swModel.GetPathName
myForm.Show vbModal
UserForm1:
Dim pdmVaultObject As New EdmVault5
Dim pdmVault As IEdmVault10
Dim pdmFolder As IEdmFolder5
Dim pdmCardViewParams As EdmCardViewParams
Dim pdmCardView As IEdmCardView63
Dim filePath As String
#If Win64 Then
Private Declare PtrSafe Function IUnknown_GetWindow Lib _
"shlwapi" Alias "#172" (ByVal pIUnk As IUnknown, ByVal hwnd As LongPtr) As Long
#Else
Private Declare Function IUnknown_GetWindow Lib _
"shlwapi" Alias "#172" (ByVal pIUnk As IUnknown, ByVal hwnd As Long) As Long
#End If
Public Function GetUserformHwnd(ByVal ufmTarget As MSForms.UserForm) As Long
IUnknown_GetWindow ufmTarget, VarPtr(GetUserformHwnd)
Private Sub UserForm_Activate()
Public Sub Setup(path As String)
filePath = path
Set pdmVault = pdmVaultObject
pdmVault.LoginAuto VAULT_NAME, GetUserformHwnd(Me)
Set pdmFile = pdmVault.GetFileFromPath(filePath, pdmFolder)
pdmCardViewParams.mlFileID = pdmFile.ID
pdmCardViewParams.mlFolderID = pdmFolder.ID
pdmCardViewParams.mlCardID = 0
pdmCardViewParams.mlX = 0
pdmCardViewParams.mlY = 0
pdmCardViewParams.mhParentWindow = GetUserformHwnd(Me)
pdmCardViewParams.mlEdmCardViewFlags = EdmCardViewFlag.EdmCvf_Normal
Set pdmCardView = pdmVault.CreateCardViewEx2(pdmCardViewParams, Me)
pdmCardView.SetFocus 0
pdmCardView.Update EdmCardViewUpdateType.EdmCvut_EnableCtrl
Dim cardWidth As Long
Dim cardHeight As Long
pdmCardView.GetCardSize cardWidth, cardHeight
Me.width = cardWidth
Me.height = cardHeight
