Obtaining date modified through the API (C#)
Im looking for a good way to obtain a files last saved/modified date. The purpose is to create a metric that can find the days in state (i.e. 13 days in manufacturing approval). The best i could find online was a stack overflow response by @AmenJlili saying to use ISwDMDocument19. However IT is being difficult to obtain/release the licence key for swDocMgr (im just an intern they don’t trust me yet). Is there anyway to alter this code that might help me find this metric?
Here is the code:
using System;
using System.Collections.Generic;
using System.IO;
using SolidWorks.Interop.swdocumentmgr;
using EPDM.Interop.epdm;
namespace PDMFileDetails
    class Program
        private static IEdmVault5 vault;
        private static SwDMClassFactory swClassFactory;
        private static SwDMApplication swDocMgr;
        [STAThread]
        private static void Main(string[] args)
            string vaultName = "PDM Sandbox";  // Replace with your actual vault name
            string rootFolderPath = @"";  // Adjust this to match your root folder path
            string requestedProjID = "";  // Replace with the PROJ_ID you are looking for
                // Initialize Document Manager
                swClassFactory = new SwDMClassFactory();
                swDocMgr = (SwDMApplication)swClassFactory.GetApplication("your license key");
                vault = new EdmVault5Class();
                vault.LoginAuto(vaultName, 0);
                if (vault.IsLoggedIn)
                    Console.WriteLine($"Connected to vault: {vaultName}");
                    List<string> matchingFiles = new List<string>();
                    IEdmFolder5 rootFolder = vault.GetFolderFromPath(rootFolderPath);
                    TraverseFolder(rootFolder, requestedProjID, matchingFiles);
                    Console.WriteLine("Files with matching PROJ_ID:");
                    foreach (var file in matchingFiles)
                        Console.WriteLine(file);
                    // Write status update email
                    WriteStatusUpdateEmail(matchingFiles);
                else
                    Console.WriteLine("Failed to log in to the vault.");
            catch (Exception ex)
                Console.WriteLine($"An error occurred: {ex.Message}");
        private static void TraverseFolder(IEdmFolder5 folder, string requestedProjID, List<string> matchingFiles)
                Console.WriteLine($"Accessing folder: {folder.Name}");
                IEdmPos5 pos = folder.GetFirstFilePosition();
                while (!pos.IsNull)
                        IEdmFile5 file = folder.GetNextFile(pos);
                        if (file != null)
                            var configurations = GetConfigurations(file);
                            foreach (var config in configurations)
                                var projID = GetVariableValue(file, "PROJ_ID", config, folder.ID);
                                if (projID == requestedProjID)
                                    string state = GetFileState(file);
                                    string dateModified = GetFileDateModified(file, folder.ID);
                                    matchingFiles.Add($"{file.Name}, State: {state}, Date Modified: {dateModified}");
                                    break;
                        Console.WriteLine($"Error processing file: {ex.Message}");
                IEdmPos5 subPos = folder.GetFirstSubFolderPosition();
                while (!subPos.IsNull)
                        IEdmFolder5 subFolder = folder.GetNextSubFolder(subPos);
                        TraverseFolder(subFolder, requestedProjID, matchingFiles);
                        Console.WriteLine($"Error accessing subfolder: {ex.Message}");
                Console.WriteLine($"Error accessing folder {folder.Name}: {ex.Message}");
        static List<string> GetConfigurations(IEdmFile5 file)
            var configurations = new List<string>();
            IEdmStrLst5 configList = file.GetConfigurations();
            IEdmPos5 pos = configList.GetHeadPosition();
            while (!pos.IsNull)
                    string configName = configList.GetNext(pos);
                    configurations.Add(configName);
                    Console.WriteLine($"Error accessing configuration: {ex.Message}");
            return configurations;
        public static string GetVariableValue(IEdmFile5 file, string variableName, string config, int folderID)
            if (file == null)
                throw new ArgumentNullException(nameof(file));
            if (string.IsNullOrEmpty(variableName))
                throw new ArgumentNullException(nameof(variableName));
            var enumVariable = file.GetEnumeratorVariable() as IEdmEnumeratorVariable10;
            if (enumVariable == null)
                Console.WriteLine("Failed to get enumerator variable.");
                return "N/A";
                enumVariable.GetVar2(variableName, config, folderID, out object variableValue);
                if (variableValue == null)
                    return "N/A";
                return variableValue.ToString() ?? "N/A";
                Console.WriteLine($"Error retrieving variable {variableName} in configuration {config}: {ex.Message}");
                return "N/A";
        public static string GetFileState(IEdmFile5 file)
                return file.CurrentState.Name;
                Console.WriteLine($"Error retrieving file state: {ex.Message}");
                return "N/A";
        public static string GetFileDateModified(IEdmFile5 file, int folderID)
                SwDMClassFactory swClassFactory = new SwDMClassFactory();
                SwDMApplication swDocMgr = (SwDMApplication)swClassFactory.GetApplication("your_license_key");
                // Get the document path from PDM
                string documentPath = file.GetLocalPath(folderID);
                if (string.IsNullOrEmpty(documentPath))
                    Console.WriteLine($"File path is empty: {documentPath}");
                    return "File path is empty";
                // Load the document using SolidWorks Document Manager
                SwDmDocumentType docType = SwDmDocumentType.swDmDocumentUnknown;
                SwDmDocumentOpenError retVal;
                ISwDMDocument19 swDoc = (ISwDMDocument19)swDocMgr.GetDocument(documentPath, docType, false, out retVal);
                if (swDoc != null)
                    DateTime lastSavedDate = DateTime.Parse(swDoc.LastSavedDate2.ToString());
                    return lastSavedDate.ToString();
                else
                    Console.WriteLine($"Failed to open document: {documentPath}, error: {retVal}");
                    return "N/A";
                Console.WriteLine($"Error retrieving file date modified: {ex.Message}");
                return "N/A";
        private static void WriteStatusUpdateEmail(List<string> matchingFiles)
                string emailContent = "Status Update for Project ID: 11953\n\n";
                emailContent += "Total files processed: \n";
                emailContent += "There is   files in state for more than 10 days\n";
                emailContent += "Name of File, state, days in state \n";
                    emailContent += file + "\n";
                string emailFilePath = Path.Combine(AppDomain.CurrentDomain.BaseDirectory, "StatusUpdateEmail.txt");
                File.WriteAllText(emailFilePath, emailContent);
                Console.WriteLine($"Status update email saved to: {emailFilePath}");
                Console.WriteLine($"Error writing status update email: {ex.Message}");
but i trust you! Ask IT for a readonly connection string to the vault db. You can get that information from the vault db quicker.
Thanks Amen, this worked perfectly. Hopefully wont be back on with anymore questions soon
I would think this is possible via the IEdmHistory3 utility. The history data array for the file in question should hold the date of the last PDM event. If this sounds like something that’s useful, I can get code posted when I’m back at work.
