Is ModelDoc2::LockModel supposed to increase performance? I’m running some benchmarks, and I am noticing it is doing the opposite.
public class Example
public static void Run()
var solidworksManager = new SOLIDWORKSInstanceManager();
var swApp = solidworksManager.GetNewInstance("", SOLIDWORKSInstanceManager.Year_e.Latest, 160);
swApp.Visible = true;
var currentLocation = (new FileInfo(typeof(Example).Assembly.Location)).Directory;
var testFile = currentLocation.GetFiles()
.FirstOrDefault(x => x.Name.Equals("tank_20lb_propane_&.SLDPRT", StringComparison.OrdinalIgnoreCase));
if (testFile == null)
throw new FileNotFoundException("Could not find 'tank_20lb_propane_&.SLDPRT' in the current directory.");
string filePath = testFile.FullName;
// Open the file
int errors = 0, warnings = 0;
var swModel = swApp.OpenDoc6(filePath,
(int)swDocumentTypes_e.swDocPART,
(int)swOpenDocOptions_e.swOpenDocOptions_Silent,
"", ref errors, ref warnings);
if (swModel == null)
throw new InvalidOperationException("Failed to open the document.");
// Scenario 1: LockModel = true
Console.WriteLine("Starting Scenario 1 (LockModel = true)");
MeasureSelectionTime(swModel, true);
swModel.ClearSelection();
Console.WriteLine("\n-----------------------------------------------\n");
// Scenario 2: LockModel = false
Console.WriteLine("Starting Scenario 2 (LockModel = false)");
MeasureSelectionTime(swModel, false);
swApp.CloseDoc(swModel.GetTitle());
swApp.ExitApp();
Console.WriteLine("\nPress any key to exit...");
Console.ReadKey();
private static void MeasureSelectionTime(ModelDoc2 swModel, bool lockModel)
var swFeature = (Feature)swModel.FirstFeature();
var ModelView = swModel.ActiveView as ModelView;
if (lockModel)
swModel.Lock();
var stopwatch = System.Diagnostics.Stopwatch.StartNew();
var rootItem = swModel.FeatureManager.GetFeatureTreeRootItem2((int)swFeatMgrPane_e.swFeatMgrPaneBottom);
TraverseTreeItems(rootItem);
stopwatch.Stop();
if (lockModel)
swModel.UnLock();
Console.WriteLine($"Total Selection Time (LockModel={lockModel}): {stopwatch.ElapsedMilliseconds} ms");
public static void PrintComponentsFlat(ModelDoc2 swModel)
Console.WriteLine("Method 1: Flat List using GetComponents");
var swAssembly = swModel as AssemblyDoc;
if (swAssembly == null)
return;
var comps = swAssembly.GetComponents(false) as object[];
foreach (Component2 comp in comps)
Console.WriteLine(comp.Name2);
// Method 2: Recursive Hierarchical Traversal using GetFeatureTreeRootItem
public static void TraverseTreeItems(TreeControlItem item, string indent = "")
while (item != null)
Console.WriteLine($"{indent}{item.Text}");
var child = item.GetFirstChild();
if (child != null)
TraverseTreeItems(child, indent + " ");
item = item.GetNext();
static void TraverseFeatureForComponents(Feature swFeature, Action<Component2> performAction)
var swSubFeature = default(Feature);
var swComponent = swFeature.GetSpecificFeature2() as Component2;
if (swComponent != null)
performAction(swComponent);
swSubFeature = swComponent.FirstFeature();
while (swSubFeature != null)
TraverseFeatureForComponents(swSubFeature, performAction);
swSubFeature = swSubFeature.GetNextFeature() as Feature;
To clone repo here: SW_API_Tips_Tricks/LockModel/LockModel at master · BlueByteSystemsInc/SW_API_Tips_Tricks · GitHub
Yup it was out of process
– AmenJlili
