If the macro tries to check-out (IEdmFile5 :: LockFile
) the document is opened in the Solidworks I get an error message that tells me the current file is in use by another application and does not check it out.
The lock and unlock file methods only works for non opened documents? If yes, is there another method to get it?
If a part or assembly file is open in Solidworks, you will have to use the Solidworks API to call ForceReleaseLocks
to free the file in order to work with it using PDM functions. Now, it’s very important to read the “Remarks” section closely as it indicates how to re-attach the file when your processing is complete. Failure to do so can result in file corruption or other errors.
https://help.solidworks.com/2016/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.imodeldoc2~forcereleaselocks.html
With drawings, the same can be done using CloseAndReopen
https://help.solidworks.com/2016/english/api/sldworksapi/SOLIDWORKS.Interop.sldworks~SOLIDWORKS.Interop.sldworks.ISldWorks~CloseAndReopen.html
It worked!
Is it possible to call an update for PDM task pane? The model got locked but the task pane only updates after a few seconds or forced by the user.
Here’s a code that it’s working for testing purposes:
Dim pdmVault As EdmVault5
Dim handle As Long
Const vaultName As String = "Your vault name"
Dim swFrame As SldWorks.Frame
Set swFrame = swApp.Frame
handle = swFrame.GetHWnd
Set pdmVault = New EdmVault5
pdmVault.LoginAuto vaultName, handle
Call checkOutFile(pdmVault, swModel.GetType)
Call checkInFile(pdmVault, swModel.GetType)
Private Sub checkOutFile(ByVal pdmVault, ByVal docType As Integer)
Dim pdmFile As IEdmFile5
Dim pdmFolder As IEdmFolder5
Dim ret As Integer
Set pdmFile = pdmVault.GetFileFromPath(swModel.GetPathName, pdmFolder)
If pdmFile.IsLocked Then Exit Sub
If swModel.ForceReleaseLocks Then
pdmFile.LockFile pdmFolder.ID, handle
If docType = swDocDRAWING Then
ret = swApp.CloseAndReopen(swModel, swCloseReopenOption_DiscardChanges, swModel)
ret = swModel.ReloadOrReplace(False, swModel.GetPathName, True)
Private Sub checkInFile(ByVal pdmVault, ByVal docType As Integer)
Dim ret As Integer
If Not pdmFile.IsLocked Then Exit Sub
pdmFile.UnlockFile pdmFolder.ID, handle, EdmUnlock_OverwriteLatestVersion
