Macro: Batch Uncheck Weldment Document Options
Macro to uncheck the following 2 Weldment Document Options from all the part files in the active assembly model. The macro will set the light weight components to resolved mode and will also skip any suppressed part components.
  1. Automatically create cut lists
  2. Automatically update cut lists
Macro libraries are set to SW2022 version. In case you’re running a different version then update/correct the macro references as suggested in this video (don’t worry on the fact that video is for fixing missing library error but check the process to update your macro library): Fix-Update SOLIDWORKS Macro References - YouTube
Get the macro from 3DSYM or CadForum
#SOLIDWORKS #API #VBA #Macro #Weldment #CutList
@Gupta9665 : Let me know if you want me to create a sub-group called useful macros.
That would be a great idea @AmenJlili
We can name it Macro Library :slight_smile:
@Gupta9665 : This is yours and the whole community.
All need submissions would require your approval.
