Inserts an axis perpendicular to the centre of a plane face
Good morning to all.
I would like to create a macro in vba that inserts an axis perpendicular to the centre of a plane face.
I was able to find the code that finds the centre of the face and the perpendicular but I cannot create the axis.
Can anyone help me?
Thanks in advance.
Fabrizio
I attach the code below.
'Copyright(C) 2025 Xarial Pty Limited
'Reference: Get parameters of face at centroid using SOLIDWORKS API
'License: License
Dim swPart As SldWorks.PartDoc
Dim swSelMgr As SldWorks.SelectionMgr
Dim swFeatMgr As SldWorks.FeatureManager
Dim swFace As SldWorks.Face2
Dim centerPoint(2) As Double
Dim normalVec(2) As Double
Dim boolstatus As Boolean
Dim swAxisFeature As SldWorks.Feature
Dim swRefAxis As SldWorks.RefAxis
Set swPart = swModel
Set swFeatureMgr = swModel.FeatureManager
If Not swModel Is Nothing Then
    Set swFace = swModel.SelectionManager.GetSelectedObject6(1, -1)
    If Not swFace Is Nothing Then
        Dim vPt As Variant
        Dim vNorm As Variant
        GetFaceCenterParameters swFace, vPt, vNorm
        Debug.Print "Coordinate at face center is: " & vPt(0) * 1000 & ", " & vPt(1) * 1000 & ", " & vPt(2) * 1000
        Debug.Print "Normal at face center is: " & vNorm(0) & ", " & vNorm(1) & ", " & vNorm(2)
        ' Coordinate del punto
Dim x As Double: x = vPt(0) * 1000
Dim y As Double: y = vPt(1) * 1000
Dim z As Double: z = vPt(2) * 1000
        ' Vettore normale (direzione dell'asse)
Dim nx As Double: nx = vNorm(0)
Dim ny As Double: ny = vNorm(1)
Dim nz As Double: nz = vNorm(2)
        ' Crea un asse usando punto e direzione
Set swAxisFeature = swFeatMgr.InsertAxis2(x, y, z, nx, ny, nz)
        'Fine disegna Asse
        MsgBox "Please select face"
    MsgBox "Please open the model"
Sub GetFaceCenterParameters(face As SldWorks.Face2, ByRef point As Variant, ByRef normal As Variant)
Dim vUvBounds As Variant
vUvBounds = face.GetUVBounds
Dim centerU As Double
Dim centerV As Double
centerU = (vUvBounds(0) + vUvBounds(1)) / 2
centerV = (vUvBounds(2) + vUvBounds(3)) / 2
Dim swSurf As SldWorks.Surface
Set swSurf = face.GetSurface
Dim vEvalRes As Variant
vEvalRes = swSurf.Evaluate(centerU, centerV, 0, 0)
Dim dPoint(2) As Double
Dim dNormal(2) As Double
dPoint(0) = vEvalRes(0)
dPoint(1) = vEvalRes(1)
dPoint(2) = vEvalRes(2)
dNormal(0) = vEvalRes(3)
dNormal(1) = vEvalRes(4)
dNormal(2) = vEvalRes(5)
point = dPoint
normal = dNormal
Hi Fabrizio,
try this one - I’ve made a few updates…
Dim swModelDoc As SldWorks.ModelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFace As face2
Dim swSurface As Surface
Dim centroid As MathPoint
Dim swMath As MathUtility
    Set swModelDoc = swApp.ActiveDoc
    Set swModelDocExt = swModelDoc.Extension
    Set swSelMgr = swModelDoc.SelectionManager
    Set swMath = swApp.GetMathUtility
    Set swFace = swSelMgr.GetSelectedObject6(1, -1)
        Set swSurface = swFace.GetSurface
        If swSurface.IsPlane Then
            Set centroid = GetCentroidOfSelctedFace(swFace)
            Dim sketchPoint As sketchPoint
            Set sketchPoint = CreateCentroidInSketch(centroid)
            Dim entity As entity
            Set entity = swFace
            sketchPoint.Select4 False, Nothing
            entity.Select4 True, Nothing
            swModelDoc.InsertAxis2 True
swModelDoc.ForceRebuild3 True
Set swModelDoc = Nothing
Set swModelDocExt = Nothing
Set swSelMgr = Nothing
Set swFace = Nothing
Set swSurface = Nothing
Set centroid = Nothing
Set swMath = Nothing
Private Function GetCentroidOfSelctedFace(swFace As face2) As MathPoint
    Dim face1(0 To 0) As Object
    Set face1(0) = swFace
    swModelDoc.ClearSelection2 True
    Dim vFace1 As Variant
    vFace1 = face1
    Dim v1 As Variant
    v1 = swModelDocExt.GetSectionProperties2((vFace1))
    Dim swCentroid As MathPoint
    Dim centroid(2) As Double
    centroid(0) = CDbl(v1(2))
    centroid(1) = CDbl(v1(3))
    centroid(2) = CDbl(v1(4))
    Set swCentroid = swMath.CreatePoint(centroid)
    Set GetCentroidOfSelctedFace = swCentroid
Private Function CreateCentroidInSketch(centroid As MathPoint) As sketchPoint
    Dim swSketch As Sketch
    Dim swSketchManager As SketchManager
    Dim transformedPoint As MathPoint
    Set swSketchManager = swModelDoc.SketchManager
    swSketchManager.InsertSketch False
    Set swSketch = swSketchManager.ActiveSketch
    Set transformedPoint = TransformPoint(centroid, swSketch)
    Set sketchPoint = swSketchManager.CreatePoint(transformedPoint.ArrayData(0), transformedPoint.ArrayData(1), transformedPoint.ArrayData(2))
    swModelDoc.SketchAddConstraints ("sgFIXED")
    swSketchManager.InsertSketch True
    Set CreateCentroidInSketch = sketchPoint
Private Function TransformPoint(centroid As MathPoint, swSketch As Sketch) As MathPoint
    Dim sketchTransform As MathTransform
    Set sketchTransform = swSketch.ModelToSketchTransform
    Set TransformPoint = centroid.MultiplyTransform(sketchTransform)
Thank you, Marcel,
I’ve just had the chance to test your modifications, and everything works perfectly.
I really appreciate your contribution.
I’ll be using it in SolidWorks CAM to create axes for rotating features, and I definitely recommend it to anyone with similar needs.
You’ve done an excellent job—thanks again!
Have a great day,
Fabrizio
