GetVisibleEntities and process vertex position
Hi guys,
I need your advice. I am trying to get all vertices from visible entites and evalute their position in sheet coordinates. the following code works fine for a part drawing.
when i process the macro in in assembly drawings the result is wrong → the coordinates doesn’t fit. what am i doing wrong? how can I get the matrix from the assembly transformation? When I use Component2.Transform2 it always returns null…
does anyone have an idea?
I am working with SW 2022 SP5
Dim swModel As ModelDoc2
Dim swView As View
Dim swDrawing As DrawingDoc
Dim selMgr As SelectionMgr
Dim status As Boolean
Set swDrawing = swModel
Set selMgr = swModel.SelectionManager
status = swModel.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
Set swView = selMgr.GetSelectedObject6(1, -1)
'Fetch visible Entities
Dim vComps As Variant
vComps = swView.GetVisibleComponents
Dim vComp As Variant
Dim comp As Component2
For Each vComp In vComps
    Set comp = vComp
    Dim vVertexes As Variant
    vVertexes = swView.GetVisibleEntities2(comp, swViewEntityType_e.swViewEntityType_Vertex)
    Dim vVertex As Variant
    Dim swVertex As Vertex
    Dim swEntity As Entity
    Dim point As Variant
    Dim modelToViewTransform As MathTransform
    Dim modelToSketchTransform As MathTransform
    Dim swScaleTransform As MathTransform
    Dim swPositionTransform As MathTransform
    Dim swSketch As Sketch
    Set swSketch = swView.GetSketch
    Dim swMathUtility As MathUtility
    Set swMathUtility = swApp.GetMathUtility
    Set modelToSketchTransform = swSketch.modelToSketchTransform
    Set swScaleTransform = ScaleTransform(swView)
    Set modelToViewTransform = swView.modelToViewTransform
    Set swPositionTransform = PositionTransform(swView)
    Debug.Print ""
    Dim swMathPoint As MathPoint
    For Each vVertex In vVertexes
        Set swVertex = vVertex
        point = swVertex.GetPoint
        Set swMathPoint = swMathUtility.CreatePoint(point)
        Set swMathPoint = swMathPoint.MultiplyTransform(modelToSketchTransform) 'Dimension to Part-Origin
        Set swMathPoint = swMathPoint.MultiplyTransform(swScaleTransform)
        Set swMathPoint = swMathPoint.MultiplyTransform(modelToViewTransform)
        Debug.Print "TransformedMathpoint => " & swMathPoint.ArrayData(0) * 1000 & " | " & swMathPoint.ArrayData(1) * 1000
        swVertex.Select4 True, Nothing
    Next vVertex
Next vComp
swModel.ClearSelection2 True
Public Function ScaleTransform(swView As SldWorks.View) As SldWorks.MathTransform
    Dim swMathUtil  As SldWorks.MathUtility
    Dim transformData(15) As Double
    Set swMathUtil = swApp.GetMathUtility
    transformData(0) = 1#
    transformData(1) = 0#
    transformData(2) = 0#
    transformData(3) = 0#
    transformData(4) = 1#
    transformData(5) = 0#
    transformData(6) = 0#
    transformData(7) = 0#
    transformData(8) = 1#
    transformData(9) = 0#
    transformData(10) = 0#
    transformData(11) = 0#
    transformData(12) = swView.ScaleDecimal
    transformData(13) = 0#
    transformData(14) = 0#
    transformData(15) = 0#
    Set ScaleTransform = swMathUtil.CreateTransform(transformData)
Public Function PositionTransform(swView As SldWorks.View) As SldWorks.MathTransform
    Dim pos As Variant
    pos = swView.GetViewXform
    transformData(0) = pos(0)
    transformData(1) = pos(1)
    transformData(2) = pos(2)
    transformData(3) = pos(3)
    transformData(4) = pos(4)
    transformData(5) = pos(5)
    transformData(6) = pos(6)
    transformData(7) = pos(7)
    transformData(8) = pos(8)
    transformData(9) = pos(9)
    transformData(10) = pos(10)
    transformData(11) = pos(11)
    transformData(12) = pos(12)
    Set PositionTransform = swMathUtil.CreateTransform(transformData)
ah, finally got it. it works for assembly drawings, for single part drawings I need to adjust the process a little bit.
I think you may have forgotten to transform the coordinates of the vertex from the component coordinate system to the top of the level assembly.
I’ve tried to reach the MathTransform of a component, but swComp.Transform2 always returns null…
Dim comps As Variant
comps = swView.GetVisibleDrawingComponents
Dim drawingComp As DrawingComponent
Set drawingComp = comps(0)
Dim swComp As Component2
Set swComp = drawingComp.Component
Dim swMathTransform As MathTransform
Set swMathTransform = swComp.Transform2
Dim vPos(2) As Double
vPos(0) = drawingComp.Component.Transform2.ArrayData(9)
vPos(1) = drawingComp.Component.Transform2.ArrayData(10)
vPos(2) = drawingComp.Component.Transform2.ArrayData(11)
