Getting the Correct UV's
I’m writing plug-in for exporting triangle-based meshes from Solidworks bodies, and using ITesselation interface to get vertex and triangulation info.
But, I have a problem - I cannot get correct per-vertex UV information. ITessellation::IGetVertexParams returns data, which does not reflect real UV mapping.
Does anyone know, how to get real UV, to reproduce result’s of Solidworks rendering?
@artem might be able to answer this!
Thanks for posting for the first time @bob and welcome to the forum!
Hello, I’m facing the same problem.
Have you found a solution?
Bruuuuh. You need a little more than that to get people to help you. Drop your VBA attempt getting those values and a sample part.
