Get Linked Cut-List Table Name
I’m attempting to retrieve the name of the linked cut-list table in the drawing using the GetKeepLinkedToBOMName method. Unfortunately, this method does not provide the linked cut-list name as expected. It functions perfectly for Bills Of Materials (BOM), but not for cut-list table..
The GetKeepLinkedToBOM method works OK for both BOM and cut-list table.
Checking with the community to see if anyone has discovered any workarounds. Thank you.
This is a bit of a bad hack IMO but it works:
Preconditions: Have view pre-selected on drawing before running this macro
#If Win64 Then
    Private Declare PtrSafe Function FindWindow Lib "User32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
    Private Declare PtrSafe Function FindWindowEx Lib "User32" Alias "FindWindowExA" (ByVal hWnd1 As Long, ByVal hWnd2 As Long, ByVal lpsz1 As String, ByVal lpsz2 As String) As Long
    Private Declare PtrSafe Function SendMessage Lib "User32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByRef lParam As Any) As Long
    Private Const WM_GETTEXT As Long = &HD
    Private Const WM_GETTEXTLENGTH As Long = &HE
#End If
    Dim swModel As ModelDoc2
    Dim swSelMgr As SelectionMgr
    Dim swView As View
    Set swSelMgr = swModel.SelectionManager
    Set swView = swSelMgr.GetSelectedObject6(1, -1)
    swApp.RunCommand swCommands_Properties, Empty
    Dim caption As String
    caption = FindLinkedBOMCaption() 'Gets caption from opened dialog window '
    Debug.Print caption
    swApp.RunCommand swCommands_e.swCommands_PmCancel, Empty
Function FindLinkedBOMCaption() As String
    Dim hwnd As Long
    hwnd = FindWindow(vbNullString, "Drawing View Properties")
    Dim myControl As Long
    Dim myControl2 As Long
    myControl = FindWindowEx(hwnd, 0&, vbNullString, vbNullString)
    myControl2 = FindWindowEx(myControl, 0&, vbNullString, "Balloons")
    myControl = FindWindowEx(myControl, myControl2, "ComboBox", vbNullString)
    Dim sLen As Long
    sLen = SendMessage(myControl, WM_GETTEXTLENGTH, 0, ByVal 0&)
    Dim sBuffer As String
    sBuffer = Space(sLen)
    Dim sStr As String
    SendMessage myControl, WM_GETTEXT, sLen + 1, ByVal sBuffer
    'Debug.Print hwnd & "  Contents: [" & sBuffer & "]" '
    FindLinkedBOMCaption = sBuffer
Thank you Alex, it is a bit crazy workaround but it works.
