I’m trying to build a macro to cycle through all the display states of the active document, and I would like to get the name of active display state of the active document.
I thought of using the Names Property of IDisplayStateSetting like this:
' Display state permutation
' A macro to cycle through all the display state of the active file.
try_:
' Comment the line below to avoid error to exit the macro, for debug only
On Error GoTo catch_
' Check if the open file is an assembly and it is saved
If swModel Is Nothing Then
Err.Raise vbError, "", "Open a file to run the macro"
If swModel.GetPathName() = "" Then
Err.Raise vbError, "", "Save the document to run the macro"
If swModel.GetType() = swDocumentTypes_e.swDocDRAWING Then
Err.Raise vbError, "", "Open an assembly or a part file to run the macro"
' Get file configurations and the active display state of the file
Dim swConfigMgr As SldWorks.ConfigurationManager
Set swConfigMgr = swModel.ConfigurationManager
Dim vConfs As Variant
vConfs = swModel.GetConfigurationNames
Dim activeConfig As Configuration
Set activeConfig = swConfigMgr.ActiveConfiguration
Dim confName As String
confName = activeConfig.Name
Dim swConf As SldWorks.Configuration
Set swConf = swModel.GetConfigurationByName(confName)
Dim vDispStates As Variant
vDispStates = swConf.GetDisplayStates
Dim swComponent As SldWorks.Component2
Set swComponent = swConf.GetRootComponent()
Dim swDSS As SldWorks.DisplayStateSetting
Set swDSS = swModel.Extension.GetDisplayStateSetting(swDisplayStateOpts_e.swThisDisplayState)
Dim activeDispState() As String
activeDispState = swDSS.Names
GoTo finally_
catch_:
MsgBox Err.Description, vbCritical, "Display state permutation"
finally_:
but the activeDispState returns empty.
Where am I wrong? Is the a better way to get the current display state with VBA?
Thanks in advance.
How did you know that the first element of GetDisplayStates is the current one? Did I miss it somewhere in the documentation?
Thanks a lot by the way!
In case anyone is interested, here the code of a macro to change the active display state with the click of a button
try_:
Dim nbrDisplayStates As Long
nbrDisplayStates = swConf.GetDisplayStatesCount
Dim activeDispState As String
activeDispState = vDispStates(0)
' Sort the array of display states
vDispStates = SortArrayAtoZ(vDispStates)
Dim i As Integer
For i = 0 To UBound(vDispStates)
If activeDispState = vDispStates(i) Then
' Get the name of the next configuration
Dim nextDispState As String
' If this is the last element of the array, restart the counter
If i = UBound(vDispStates) Then
nextDispState = vDispStates(0)
nextDispState = vDispStates(i + 1)
Dim retValue As Boolean
retValue = swConf.ApplyDisplayState(nextDispState)
GoTo finally_
GoTo finally_
catch_:
MsgBox Err.Description, vbCritical, "Cambia stato di visualizzazione"
finally_:
swModel.GraphicsRedraw2
Function SortArrayAtoZ(myArray As Variant)
Dim i As Long
Dim j As Long
Dim Temp
'Sort the Array A-Z
For i = LBound(myArray) To UBound(myArray) - 1
For j = i + 1 To UBound(myArray)
If UCase(myArray(i)) > UCase(myArray(j)) Then
Temp = myArray(j)
myArray(j) = myArray(i)
myArray(i) = Temp
Next j
Next i
SortArrayAtoZ = myArray
Active display state is always the first element of GetDisplayStates. Check remarks in the help page here GetDisplayStates Method (IConfiguration) - 2022 - SOLIDWORKS API Help
