I do not know the exact internal implementation of regasm.exe, but one of the biggest limitations is that regasm.exe does not support assembly binding redirects.
This means a COM DLL can fail to load if it depends on other assemblies with different versions than the ones originally expected. You can see the regasm.exe errors in the console.
I am wondering if anyone has tried building their own lightweight alternative to regasm.exe.
From what I understand, the minimum implementation would likely involve:
Creating the required registry keys under:
HKEY_CLASSES_ROOT\CLSID{YourGuid}
HKEY_CLASSES_ROOT\ProgID
HKEY_CLASSES_ROOT\Interface{YourInterfaceGuid}
HKEY_CLASSES_ROOT\TypeLib{YourTypeLibGuid}
InprocServer32 entries pointing to mscoree.dll
Loading the target assembly with reflection
Finding COM-visible classes
Reading attributes like GuidAttribute, ProgIdAttribute, ComVisibleAttribute, ClassInterfaceAttribute, etc.
Locating methods marked with RegisterFunctionAttribute
Invoking the RegisterComFunction method manually after the registry entries are created
Potentially supporting custom assembly resolution logic or binding redirects during activation
Has anyone here attempted something like this, or found a good open-source implementation?
