Change the color of a component return black grafics
Hi!
I’m trying to change the color of the components of an assembly with a VBA macro.
Searching online I saw two ways to change the color of a component:
  1. using the method MaterialPropertyValues
  2. using GetDisplayStateSetting and DisplayStateSpecMaterialPropertyValues as shown here
I wonder what are the main differences between the two and if there are any pro or cons using one method or the other.
Furthermore if I use the second method, even with the example from the SolidWorks API Help, the changed component appears black unless the component is closed and re-opened or the appearance is changed from the UI. I saw others complaining about this behavior:
Any idea or suggestion?
Thanks in advance.
I reported a bug recently that sounds like what you’re seeing. Here’s what I reported:
As it turns out, the Shininess parameter in SetMaterialPropertyValues2 does not do what it says in the documentation.
SetMaterialPropertyValues2 Method (IComponent2) - 2022 - SOLIDWORKS API Help
From the input values for Shininess that I have tried, the formula does not equal “shininess = 1- Specular spread”. It’s looks like “Specular spread = 0.001 / shininess” or the other way around "shininess = 0.001 / Specular spread ". So it’s a factor 1000 off and there is a division, not a minus, used in the equation.
Thank you for the replay, I will try what you suggest.
Meanwhile I settled to use MaterialPropertyValues, I saw no major drawbacks.
In case anyone is interested, here the code of a macro that, on the active assembly:
  • unlink the display states from the configuration
  • delete all display states except the ones defined in DEFAULT_DS and RAND_COLOR_DS
  • in the display state RAND_COLOR_DS set random colors for each component, giving all the instances of the same component the same color
' PurgeDisplayState
' Delete display states (DS) in the active file except the one defined in DEFAULT_DS and RAND_COLOR_DS, set random color for components in RAND_COLOR_DS
' Display states to preserve
Const DEFAULT_DS As String = "Default_Display state-1"
Const RAND_COLOR_DS As String = "COLORS"
Dim vMatProp As Variant
Type BomPosition
    model As SldWorks.ModelDoc2
    comp As SldWorks.Component2
    ModelPath As String
    Configuration As String
    Quantity As Double
    Description As String
    Price As Double
End Type
try_:
    ' Comment the line below to avoid error to exit the macro, for debug only
    On Error GoTo catch_
    ' Check if the open file is an assembly and it is saved
    If swModel Is Nothing Then
        Err.Raise vbError, "", "Open an assembly to run the macro" ' Open an assembly to run the macro
    If swModel.GetPathName() = "" Then
        Err.Raise vbError, "", "Save the document to run the macro" ' Save the document to run the macro
    If Not swModel.GetType() = swDocumentTypes_e.swDocASSEMBLY Then
    vMatProp = swModel.MaterialPropertyValues
    Dim swAssy As SldWorks.AssemblyDoc
    Set swAssy = swApp.ActiveDoc
    swAssy.ResolveAllLightWeightComponents True
    ' Unlink display states from configuration
    Dim swConfigMgr As SldWorks.ConfigurationManager
    Set swConfigMgr = swModel.ConfigurationManager
    swConfigMgr.LinkDisplayStatesToConfigurations = False
    Dim vConfs As Variant
    vConfs = swModel.GetConfigurationNames
    ' Get the active configuration of the file
    Dim activeConfig As Configuration
    Set activeConfig = swConfigMgr.ActiveConfiguration
    ' Check if default and random display state exists
    Dim i As Integer
    Dim defaultFound As Boolean
    defaultFound = False
    Dim randomFound As Boolean
    randomFound = False
    Dim confName As String
    confName = activeConfig.Name
    Dim swConf As SldWorks.Configuration
    Set swConf = swModel.GetConfigurationByName(confName)
    Dim vDispStates As Variant
    vDispStates = swConf.GetDisplayStates
    Dim j As Integer
    For j = 0 To UBound(vDispStates)
        Dim dispStateName As String
        dispStateName = vDispStates(j)
        If dispStateName = DEFAULT_DS Then
            defaultFound = True
        If dispStateName = RAND_COLOR_DS Then
            randomFound = True
    Dim retValue As Boolean
    ' Crete default display state
    If defaultFound = False Then
        retValue = activeConfig.CreateDisplayState(DEFAULT_DS)
    ' Create random color display state
    If randomFound = False Then
        retValue = activeConfig.CreateDisplayState(RAND_COLOR_DS)
    ' Delete unnecessary display states
        If Not (dispStateName = DEFAULT_DS) And Not (dispStateName = RAND_COLOR_DS) Then
            retValue = swConf.DeleteDisplayState(dispStateName)
    ' Set current display state as random color
    swConf.ApplyDisplayState RAND_COLOR_DS
    'Get flat bom
    Dim bom() As BomPosition
    bom = GetFlatBom(swAssy)
    ' Apply random color to component in flat bom
    RandomColor bom, swModel
    Dim View As SldWorks.ModelView
    Set View = swModel.ActiveView
    Dim rect As Variant
    Set rect = Nothing
    View.GraphicsRedraw (rect)
    MsgBox "Macro completed"
    GoTo finally_
catch_:
    MsgBox Err.Description, vbCritical, "Purge display state"
finally_:
Function GetFlatBom(assy As SldWorks.AssemblyDoc) As BomPosition()
    Dim vComps As Variant
    vComps = assy.GetComponents(False)
    Dim i As Integer
    For i = 0 To UBound(vComps)
        Dim swComp As SldWorks.Component2
        Set swComp = vComps(i)
        If swComp.GetSuppression() <> swComponentSuppressionState_e.swComponentSuppressed And Not swComp.ExcludeFromBOM Then
            Dim bomPos As Integer
            bomPos = FindBomPosition(bom, swComp)
            If bomPos = -1 Then
                If (Not bom) = -1 Then
                    ReDim bom(0)
                    ReDim Preserve bom(UBound(bom) + 1)
                bomPos = UBound(bom)
                Set bom(bomPos).model = swComp.GetModelDoc2
                Set bom(bomPos).comp = swComp
                bom(bomPos).ModelPath = swComp.GetPathName()
                bom(bomPos).Configuration = swComp.ReferencedConfiguration
                bom(bomPos).Quantity = 1
                GetProperties swComp, bom(bomPos).Description, bom(bomPos).Price
                bom(bomPos).Quantity = bom(bomPos).Quantity + 1
    GetFlatBom = bom
Function FindBomPosition(bom() As BomPosition, comp As SldWorks.Component2) As Integer
    FindBomPosition = -1
    If (Not bom) <> -1 Then
        Dim i As Integer
        For i = 0 To UBound(bom)
            If LCase(bom(i).ModelPath) = LCase(comp.GetPathName()) And LCase(bom(i).Configuration) = LCase(comp.ReferencedConfiguration) Then
                FindBomPosition = i
                Exit Function
Sub GetProperties(comp As SldWorks.Component2, ByRef desc As String, ByRef prc As Double)
    Dim swCompModel As SldWorks.ModelDoc2
    Set swCompModel = comp.GetModelDoc2()
    If swCompModel Is Nothing Then
        Err.Raise vbError, "", "Failed to get model from the component"
    desc = GetPropertyValue(swCompModel, comp.ReferencedConfiguration, "Description")
    Dim prcTxt As String
    prcTxt = GetPropertyValue(swCompModel, comp.ReferencedConfiguration, "Price")
    If prcTxt <> "" Then
        prc = CDbl(prcTxt)
Function GetPropertyValue(model As SldWorks.ModelDoc2, conf As String, prpName As String) As String
    Dim confSpecPrpMgr As SldWorks.CustomPropertyManager
    Dim genPrpMgr As SldWorks.CustomPropertyManager
    Set confSpecPrpMgr = model.Extension.CustomPropertyManager(conf)
    Set genPrpMgr = model.Extension.CustomPropertyManager("")
    Dim prpVal As String
    Dim prpResVal As String
    confSpecPrpMgr.Get3 prpName, False, "", prpVal
    If prpVal = "" Then
        genPrpMgr.Get3 prpName, False, prpVal, prpResVal
    GetPropertyValue = prpResVal
Sub RandomColor(bom() As BomPosition, swModel As SldWorks.ModelDoc2)
    ' Variable declaration
    Dim swModelDocExt As SldWorks.ModelDocExtension
    Dim swDisplayStateSetting As SldWorks.DisplayStateSetting
    Dim swAppearanceSetting As SldWorks.AppearanceSetting
    ' Get model display property and set display settings
    Set swModelDocExt = swModel.Extension
    Set swDisplayStateSetting = swModelDocExt.GetDisplayStateSetting(swThisDisplayState)
    swDisplayStateSetting.Option = swThisDisplayState
    swDisplayStateSetting.PartLevel = False
    ' Get assembly component, with repetition
    Dim swAssembly As SldWorks.AssemblyDoc
    Set swAssembly = swModel
    Dim vElementArr As Variant
    vElementArr = swAssembly.GetComponents(True)
    Dim swSelMgr As SldWorks.SelectionMgr
    Set swSelMgr = swModel.SelectionManager
    Dim swSelData As SldWorks.SelectData
    Set swSelData = swSelMgr.CreateSelectData
    Dim bRet As Boolean
    Dim i As Integer
    Dim j As Integer
        bRet = bom(i).comp.Select4(False, swSelData, False)
        Randomize
        vMatProp(0) = Rnd 'Red
        vMatProp(1) = Rnd 'Green
        vMatProp(2) = Rnd 'Blue
        vMatProp(3) = Rnd / 2 + 0.5 'Ambient
        vMatProp(4) = Rnd / 2 + 0.5 'Diffuse
        vMatProp(5) = Rnd 'Specular
        vMatProp(6) = Rnd * 0.9 + 0.1 'Shininess
        bom(i).comp.MaterialPropertyValues = vMatProp
        ' Change color for the components with the same filename
        For j = 0 To UBound(vElementArr)
            ' Check if component is suppressed
            Dim swArrComponent As SldWorks.Component2
            Set swArrComponent = vElementArr(j)
            If Not swArrComponent.GetSuppression2 = swComponentSuppressed Then
                If bom(i).model.GetPathName = vElementArr(j).GetModelDoc2.GetPathName Then
                    bRet = vElementArr(j).Select4(True, swSelData, False)
                    vElementArr(j).MaterialPropertyValues = vMatProp
    'Redraw to see new color
    swModel.GraphicsRedraw2
Some reference material:
