Does anyone know to change the material in a SOLIDWORKS part without affecting the existing appearance? Basically, we don’t want the material to apply its texture and messing up the existing appearance.
Edit: I need a VBA macro. or some directions…
@BigCrazyAl : Is there a way to do this via the API?
@AmenJlili Woops! I missed that tag.
I have to give credit where it’s due to @artem for his library of code snippets from the link below.
'Copyright(C) 2020 Xarial Pty Limited
'Reference: https://www.codestack.net/solidworks-api/document/materials/change-apply-appearance/
'License: https://www.codestack.net/license/
Dim swPart As SldWorks.PartDoc
Set swPart = swApp.ActiveDoc
If Not swPart Is Nothing Then
Dim swMatVisPrps As SldWorks.MaterialVisualPropertiesData
Set swMatVisPrps = swPart.GetMaterialVisualProperties
swMatVisPrps.ApplyAppearance = False
swPart.SetMaterialVisualProperties swMatVisPrps, swInConfigurationOpts_e.swAllConfiguration, Empty
MsgBox "Please open part document"
@BigCrazyAl : Thanks. Seems to work now.
@artem : Thanks for the code. Does this work if the document and sldworks are hidden?
@AmenJlili, I have never checked, but I doubt it. Usually, anything related to visuals requires models to be visible, although there seems to be no reason to have doc visible to apply the material, but you never know…
